Nov 2017
I’m brand new to 3D printing and still waiting on my printer. I figured I’d start getting familiar with Cura so I’ll be ready to print when it arrives. I have run across an issue with a 3d model I built myself in Blender 3d where the slices don’t fill the entire model shadow. What causes this and how would I fix it? See the attached image.
I don’t know if this will help. Try to import the 3D model into Microsoft 3D builder. Then if it suggests to repair the model, please do that. Then save and exit. Now import the new model into cura. This might solve your problem. Thos usually did the magic when I design something in blender.
Those tail areas may be to thin to print. Try reducing the extrusion width or the nozzle diameter like .4 to .39, .38 etc. and see if it makes a difference.
Alright everyone, thanks a bunch for the advice and tips. I tried to import the model into MS 3d Builder, but it thought the thing was fine, so I gave up on that route. I also tried it in CraftWorks, and finally Slic3r, which is how I figured out that, yes, the vertical fins are too thin at the rear. I forgot when I modeled it that I tapered those to almost zero in the back. I’ll have to increase the rear width.
Thanks for the solution!
