I am surprised that using a Sense didn’t put you off Cubify products immediately!
Speed of the Cube 3 is still an issue especially when printing in two colours. It seems to only heat one extruder at a time so swapping between colours takes some considerable time, similar to Cube Pro. The stock print of a two colour number which is about 80mm in Z height has been running over night as it is a 9 hour print. I will attempt to tag the result onto a post later.
The test print is pretty nice. It took about 9 hours to print with a 40mm Z height but the quality of the print is really good. The layers are virtually invisible and there were no visible flaws in the print. I am rather impressed.
I have a cube 3 printer. It pumps out high quality prints at an expensive material cost. It is an extremely easy machine to use and needs very little maintenance.
I have a Cubex The Printer Quality It’s good, But Filament Cartidges are very expensive, hope Cubify take lower price for Catridges soon…
from the left: #CubePro (PLA with INF), #CubePro (PLA), Makerbot (PLA)
I’ve got a cube trio and because of the high cartridge price I’m rebuilding the machine using the mechanics as a Base with new electronics. I hope this wil work …
If you do, will you post instructions for others on how to do the same thing? We are running into the same problem - great “bones” but less than idea control system.
I’ll post how to do this rebuild in time
Hi LeMonde,Thanks for sharing. May I know about the post processing of these models? If any…
No post processing. The purpose of this photo was to show bad results with CubePro printer
There is a thread on simplify3d where someone gives detail on the arduino he made to control his cubepro and avoid using original cartridges https://forum.simplify3d.com/viewtopic.php?f=8&t=2067&sid=a4c847876f1e8f3b04c3dc26b70f0b07&start=50
Unfortunately, I don’t know much about arduino or mechanics but I guess I’ll have to learn if I want to give some use to my useless cube not-so-pro trio
What about the support material? Usage and removal. Can you elaborate on the post processing for that?
This is exactly what I’m gonna try…instead the ramps 1.4 I’m going to use an ultimaker 1.5.7 shield or a megatronics v3.0.
Cubepro is a very solid and beautiful machine but it is handicapped by a definitely non pro software. Slicing is truly a problem and support generation is just plain awful, they are impossible to remove. The best trick I have found is printing ABS with PLA supports. I use a rice cooker to dip the model in hot water so pla will melt before abs; an unnecessary process with a decent slicer. If you haven’t purchased one already, I strongly suggest you to look for other printer options.
Now offered is a water dissolvable support material for the CubePro called INF or Infinity. Used with PLA
I have been trying to print a “fusion 360 .stl model” with my Cube3 but I don’t understand what goes wrong if it is the printing values when exporting or the settings used before printing but the model has a melting look, not precise or smooth, probably too much filament used or the printers temperature is not right. Can someone check on my pictures and perhaps advise on what setting might be wrong before printing? thanks.
Hi Jerommeke
I have just joined the Hub, I also have a Cubepro and I am not happy.
I should have done more research prior to purchasing the thing…
Have you had any success with your rebuilding?
Regards
Mike
Hack devices for all printers from Cubify, Cube, CubeX, CubePro … www.cube3dfree.com … worldwide products
i agree this is a great printer but how do you solve the jamming in the nozzle my printer has been crippled with it and i end up wasting alot of filament
