Hi
Every time I switch filament brand/type, I struggle to quickly find optimal settings which will give great results including first layer (they tend to be funny).
Can you share your settings (temperature, layer height, etc) for different filament types and brands?
Good idea opening a separate Cubicon discussion! I get good Hatchbox PLA results using default settings, 0.1mm layer and 50-55C bed. I’ll double check and post detailed settings later. I haven’t printed ABS for a while… I had many issues printing nylon with wrong settings in the past - almost lost the print head!
Has anyone tried flexible filament with the standard cubicon head?
I just purchased a Cubicon Single Plus. I’ve been using stock setting on Cubicreator 3.1.2 and getting great results. I also have Simplify3D but I don’t see a reason to use it yet. If you guys have any suggestion on settings or anything please post it here. Cubicon Single is a great machine and not much is written about it. Thanks.
