My CTC Bizer dual arrived with several things wrong with it. I have run service and support for MakerBot 3D printers and know them well - so I already upgraded the extruder, tightened the frame and got it printing OK.
The temperature reported by both thermocouples at room temperature is about right - IE it matches my MakerBots and RepRaps which use different sensors.
At printing temperatures, the thermocouples both seem to report far too high. For a period I could use the machine, but I had to set the print temperature to 270 degrees C to print ABS. A few degrees lower at 265 and it would print weakly with stringing and underextrusion, a few degrees lower still at 260 and no extrusion at all.
Now, things seem to have got worse, and I cannot print at all. Raising temps between 275 and 280 the printer tries to extrude, weakly, getting better with more temperature, but at the safety limit of 280 in MakerBot Desktop, it’s still unable to print at all. This goes for both extruders.
I hadn’t tried any serious printing on the left extruder until I tried swapping to it as a result of this issue so I can’t say whether they have both gone wrong in the same way - but the current behaviour is very consistent between them.
My question is - do I have 2 faulty thermocouples, is there a known issue with the way these are wired, or is there calibration that can be done to sort these out? If necessary I have a spare genuine MakerBot thermocouple I could try, but prefer to keep that unused unless necessary.
I was using the firmware 7.2 (with bits of Sailfish I believe) that came with the CTC. I upgraded to MakerBot’s 7.6, the latest available via MakerBot Desktop, this made no difference. I’m trying to run from MakerBot Desktop (was 3.9, now upgraded to 3.10).
Hope CTC or a fellow owner can help - got no meaningful response from my eBay seller…
Thanks! Alex
created
Sep '16last reply
Feb '17- 4
- 2.2k
likes
- 1
link
