May 2016
Hi, I just got a CTC 2nd generation (I think - black paint over wood body). I put a 3D file in the G format on an SD and put it in the 3D printer and it will not read it. Does any one know how to get a 3D file put on a card that this 3D printer can read please? I will deeply appreciate your advice please and thank you
    May '16
    May '16
  • 14
  • 7.6k
  • 6
I had the same issue. Solved it but using makerbot platform to create the 3g file. If you look at the file extension on the demo files you will see they match the makerbot file type.
Makerbot printers and clones such as the ctc printer don’t read G-Code files, you will have to covert it using gpx converter or you can slice the model in replicator G or the makerbot software and export the file as an X3G file which is what makerbots read
And, if you have the proper extension and file type, I have noticed the CTC’s are picky about the file name. They don’t like Spaces, special characters or lengthy file names. Keep it down to the 7.3 file name.
Honestly, mixed emotions. The instructions are in Chinese, but I was able to read alternative sources and the pdf text enough to
print an impressive first print from the SD card provided with the printer. It looks awesome the firs print in orange PLA. It is the bust of a woman. However, after marveling at it for weeks I got bored and wanted a new challenge. This is where my problems kinda began. I downloaded and STL file and put in on the card and got into the world of trying to covert stl files to something this printer will recognize. It gives me this weird message so I thought maybe it was the mac I use and decided to try a microsoft platform. I formatted the SD card but the CTC printer requires FAT16 and my formatting options did not have that but did have FAT32 and a few others. I loaded up the card and got the same error message. Now I do not know whether or not it is the formatting in a non FAT16 format of the actual SD card that is the problem, or the aforementioned problem of converting the G file into a xG thingy (sorry guys I am a film maker and this stuff is like totally new to me I am trying to make a birthday present for my beloved sister so I am kinda clueless). In fact, I am scratching my head wondering and saying hmm because I did use the maker bot to convert the stl file into a G 'something and I could have sworn that G ‘something’ was the xG3 file or whatever…Im gonna be so embarrassed when i open that replicator program back up and see an option for the right file format smh lol…sorry guys…learning/growing pains
Firmware version 1.0
is there something I can do to make the SC card read with this particular firmware?
The firmware version shows when I turn on the printer.
It beeps a noise and then displays the following on the screen:
The Creator
