May 2016
Hi, I just got a CTC 2nd generation (I think - black paint over wood body). I put a 3D file in the G format on an SD and put it in the 3D printer and it will not read it. Does any one know how to get a 3D file put on a card that this 3D printer can read please? I will deeply appreciate your advice please and thank you
    May '16
    May '16
  • 14
  • 7.6k
  • 6
I had the same issue. Solved it but using makerbot platform to create the 3g file. If you look at the file extension on the demo files you will see they match the makerbot file type.
Firmware version 1.0
is there something I can do to make the SC card read with this particular firmware?
The firmware version shows when I turn on the printer.
It beeps a noise and then displays the following on the screen:
The Creator
