Aug 2015
My CTC 3D printers been great for the past 3 weeks since I got it however as of yesterday I can not longer print from it :frowning:
During a print the printer will either completely lock up or it will reboot.
I can re produce this behavior by using the JOG mode in the printers menu.
If I JOG the Y axis up and down a few times it will start to do very minor stutters as it moves and then if I continue to JOG it for a few more seconds the printer will do one of the following.
- Lock up completely requiring a hard reboot
- Reboot on its own
- Display “Platform Failure!” (rare) and lock up
I have performed the following troubleshooting while awaiting a response from the seller and have found no change with my printers fault.
- Switched the X and Y steppe modules with the A and B extruders
- Switched the Y axis Steppe motor with Left Extruders
- Re routed some of the steppe control wires away from the motherboard a little
- Re loaded the firmware
I really don’t know what else I could try other than being sent a replacement Motherboard. The printer is only a few weeks old!
Any help would be much appreciated! I really need this printer back up and running!
    Aug '15
    Jan '16
  • 5
  • 1.1k
  • 3
I would check your end stop cables. They are a known issue with this style printer. Unplug them and do your jogging to see if they are the culprit.
Thanks Adam I will try this when I get home tonight.
I really hope this is the cause as the end stops look quite cheap and easy to replace.
I did notice the other night one of my end stops was slightly bent preventing it triggering. I think the head slammed into it…which I fixed by bending it back into the correct place. Perhaps there was more damage than I originally thought.
I will post my findings in a few hours!
I am happy to report I have fixed the problem!
I tried the JOG with the end stop module cable disconnected and I was not getting crashing however I was still getting slight stutters on the Y axis. I then “brushed past” the X axis Steppe motor cable (one of the cable which MOVES with the printer heads axis moments) while still in JOG mode and the X axis stuttered slightly!
This was when I realised the fault was with this steppe motor cable. I connected this cable to the Y axis steppe motor and found that the issue followed the cable to this other steppe motor.
I made up a new cable using new (thicker) wire and the existing connectors (since I did no have new connectors to use) and everything has been working perfectly since!
Thank you so much Adam for pointing me in the right direction!
4 months later
I am very grateful for your post. I had the same issue and came across this post. Within minutes I had found the problem. Faulty stepper wire on the x axis. Replaced it and issue solved.
i used a proper mesh loom to fix it after replacing the cables
