Hello sir,
Just for you to ponder Last night after removing the thermistor I re-took meter readings from the HBT this time without the thermistor fitted! So open at all four tabs both for old and new thermistor positions results are:-
5v to Signal = 4.964
Signal to ground yellow wire = 0.498
Signal to ground green wire = 0.497
I used probe clips on the meter this time as to not have any influence from my body, I noticed that at first the readings for:-
Signal to ground yellow and Signal to ground green took some time to settle as both at first produced fluctuating readings from the 0.550 range up to 0.950`s then back down again several times until finally settling at the figures above. Is that normal would have thought the readings would have been stable from the outset?
Sorry for imposing upon you feel free to drop this mystery anytime, I would totally understand.
Would I be right concluding it can only be one of three things:
1. Since the fault was apparent from the start its a hardware problem.
The HBP or the main board?
2. I`m a prat and have done something wrong! ( Although all I have done is print using a cold HBP and I know how to turn on and off the HBT within display settings.)
3. This is some kind of software problem caused by the sailfish 7.6 firmware I upgraded ( If this was the case why did the HBP not work with original firmware?) Is it worth trying to reinstall said software and have I used the correct firmware and selected the correct board? See info as displayed on LCD Information:
SAILFISH REPLICATOR1 (cannot see if any other characters are on this line or is it complete?)
Free SRAM 800 ( This line seems to flicker )
Thing 32084 r1220M
Firmware Version 7.6
One more change Ive noticed is that since upgrading firmeware the bed levelling procedure dosn
t use the four or five positions it offered originally ; press menu to move to different locations and measure. Now the head just goes to the centre of the HBT and thats it! Then press M to exit. All other new menu
s and sub menu`s seem to be fine just not sure if this is relevant.
Thought I`d mention in case this pointed to possible firmeware issue.
