Feb 2017
Hi sorry for the delay in replying had to go out.
Just took measurement:
Meter set at 20v dc measured from 5v to ground on HBP this gave a reading of 4.9v I assume that`s about right! I imagine that the fault if there is one could be further down the line.
Dont know what the capacitors role in the circuit is?
Am I just jabbering junk please feel free to say so; just trying to use logic could be completely wrong!
The capacitor is just for decoupling, it’s not significant (unless it’s faulty, unlikely).
Unplug and measure the resistance between the 5V and the SIG pads, and also the resistance between GND and SIG. You’ll want your meter in the ~100K range.
Hi Jon,
My Meter has`nt a 100k range so took readings set at 200k
Then borrowed another meter so I will give two sets of readings one from each as I am not familiar with meter reading I have attached photos of both types of meter as well as settings used.
First meter Vici set in kilohm range Reads as follows: (This is More of an auto reading meter also has a auto range but I set it to kilohms hope thats right!)
5v to Signal = 4.694K
Signal to Ground yellow wire = 0.518K
Signal to Ground green wire = 0.511K
Readings from second meter set at 200K as follows:
5V to Signal = 4.7
Signal to ground yellow wire = 00.5
Signal to ground green wire = 00.5
Not sure but both meters seem to agree I think!!!
HBT Disconnected from machine when readings taken.
Hope these are correct settings
Ignore display on meters just notice settings if that makes sence.
There you are then. Your NTC is either knackered, or the wrong sort. It should be around 100-120 K ohms at room temperature, and its reading 0.5k.
Well thats a surprise! I purchased and fitted the new one when the HBP wouldnt work with the original as I had read and seen on you tube that the original should be replaced due to inaccuracy issues. Is it possible that BOTH original and replacement thermistors are faulty How unlucky is that!
I purchased the 100K NTC 3950 Thermistor from ebay (" Ideal for 3D printers ") obviously NOT!!!
I can`t thank you enough for the time and effort you have put into diagnosing this problem!
I will send for a new thermistor difficult to find a genuine supplier can you recommend?
I will keep you informed should I get a new part and fit. Hope our little adventure is also helpful to anyone else who ends up having a similar problem; GOOD to know there are people like yourself out there prepared to help people with little or no knowledge and wish to pursue new hobbies ect.
Thanks again.
PS. Curiosity killing me! So Ive cut off the thermistor and taken a reading straight from the component legs Ive taken a picture of the result ??? Am I wrong or is that near 100K?
Can you get the printer on at all? If so you can go to the general settings and do a factory reset on the printer it will reset all to defaults including the firmware. Also if its not working you can try and contact the seller you bought it off and get replacement parts as it should have a years warranty i got a new motherboard when my USB chip blew in mine for free.
Factory reset just wipes EEPROM, it won’t restore the original firmware.
Yes the printer operates all except the HBP have already tried what you have suggested and comments from Jon are correct!
CTC have agreed to send a new HBP when it will arrive not sure.
Glad to here you have got it sorted. Forgot to mention when I upgraded to my home build HBP I also upgraded the power supply. I’m in the middle of building a XL ctc but running on Arduino and ramps 1.4 (still struggling with firmware (not been well back trouble put me in hospital for 2 week)). My work shop is in the loft with ladders as access so it’s been put on hold until I’m well enough. Pic so far.
Hello Sir,
Thanks for your comment. That looks a great machine have you cut the cabinet yourself; acrylic is it?
Just trying some ABS having problems sticking to bed, Im using a glass bed with glue sticks think my problem is the new heat bed not reaching 110C. I have not yet fitted the new thermistor and the original supplied on the board just dosnt do the job.
Still practising. Sorry to hear you are unwell I know what back trouble is like suffer from it myself not long had an epidural ( Don`t recommend as it did me no good at all) Hope you recover soon.
