I have a ctc and my motherboard burned out. I bough a new one and everything works, except my temperature reads from the extruder thermocouples are not accurate. They read 180c, but its actually at around 230c. If anyone knows how i could fix this, that would be great. The main question though is that after i installed my new motherboard, the HBP does not work and it says temperature failure and N/A for temperature. I thought it was the thermistor so i bought a new one but still nothing. I ohmed out the original one and it ohms out at 106k at room temp which is ok, so i ruled that out. the 2 resistors both ohm out at 102 and 472. So the only thing left is the capacitor. Does anyone know what is the cap value for it? I am assuming the capacitor burned out when the MB burned. Does anyone have any idea what else it could be? thanks
I know the motherboard on the CTC machines uses a 100k thermistor in a resistor bank and that if your board reads NA or not readable or something like that while it’s connected you have burned a trace on the board
I did this by accident once I switched of the heated bed option in replicator g and forgot and my printer said NA for build platform temp if you plug the machine into rep g flash sailfish on to it and selected bhp installed to yes and plug in your heated bed the. It should read it
CTC has very bad extruder design and also they have USB key so you can not use generic filament after every filament roll they are forcing you to buy another USB key and often during the print it will stop false error will come up Roll INv. means change USB key. more then half the jobs dissenter extruder need major update
also CTC filament is so fragile that it can break during any print job so its very hard to complete the print one another always some problems are there.
The extruder design is very good in the CTC printer, they did not design it. As far as the USB+ keys go, they can be reprogrammed at home. Also the usb+ timer counts preheat time, making it extra sucky.
My CTC printer is not working any more its showing on display ROLL INV. that is because of USD key before dying it already had lot of issues with extruder. as “adamcooks” said USB key can be programmed at home can you or any body tell me how?
Man I dont like this CTC dual head printer it gives me lot of troubles from the beginning instead i found ver nice with prusa i3.
It’s not a usb, don’t plug it into a computer as it will blow it and what you need to do is reflash the software with sailfish which I think is out of your capability as it’s quite a hard process as you have to do it over serial not through usb search YouTube for usb ctc and you will find the video how to fix
I’ve never dealt with the ones with USB. That makes no sense to me and I think it’s a scam. With that being said, the ctc is a great printer when you do certain mods. I’ve done 6 hour prints with no issues at all, but in the beginning I could barely leave it alone for 5 min.
Alright everyone, this was a stupid thing from my part when I replaced the burned motherboard I connected the bed backwards. I don’t know why it is not occurred to me to check that first. Thank you all for the help. If anyone knows how to calibrate the firmware to read the correct temperature for the extruders though, that would be great. Thanks
There is no calibration in the firmware for the t/c. It has everything to do with how the eyelet is attached to the heater block. T/c is just accurate, plain and simple. As long as it’s constantly off, treat it as a temperature set point and not an actual temperature ( which really is the truth of the situation ).
