I accidentally shorted the thermocouple with the 24v of the heater cartrige. That burned the the voltage amplifier in the mob for that thermocouple and numerous other components in the mb. I replaced the mb and got 2 new thermocouples for the extruders from maker geek from maker geek. The mounting is the same as the old thermocouple. I don’t know if the bed got messed up when the old mb burned, but that was my assumption that the cap or the thermistor got screwed up. I am not totally sure how they would mess up though since the bed circuit an extruder circuit look to be isolated from each other by what I can see in the mighty board schematic.
I have loads of parts for these machines if you need any a replacment heated bed di think are around £40 and they are flahsforge style so they read properly straight away and don’t require changing the thermistor, and if you touch any two positive and negitive wires on these machines the board blows as there is no diode back protection
Yeah, that’s how I blew the first mb. I am trying to fix my bed though, are you saying it’s broken beyond repair? Can I test the connection on the connector and see if I am getting proper voltage from the motherboard? Or will this fry my board? I know if the motherboard gets no read from the thermistor it will not turn on the 24v to heat the bed. But there should still be voltage coming into the Bed from the mb into the thermistor circuit.
If you get a thermistor stick it in the red and yellow connector wires on the heated bed connector on the right hand side of the connector and the connect the multimeter to the red and black wires and turn the machine on the bed will read like 150+ °c and turn on the heated bed and that’s the quickest way to measure the voltage
Was the printer reading the thermistor over what you set it ? I remembered that you have to get it to read below 130°c before the heated bed turns on and I think your board is blown not your new motherboard
Alright everyone, this was a stupid thing from my part when I replaced the burned motherboard I connected the bed backwards. I don’t know why it is not occurred to me to check that first. Thank you all for the help. If anyone knows how to calibrate the firmware to read the correct temperature for the extruders though, that would be great. Thanks
There is no calibration in the firmware for the t/c. It has everything to do with how the eyelet is attached to the heater block. T/c is just accurate, plain and simple. As long as it’s constantly off, treat it as a temperature set point and not an actual temperature ( which really is the truth of the situation ).
