Dec 2016
Hi does anyone know where I can get a direct replacement board for my printer, the usb port has failed so need to replace as its just not practical using the sd card slot all the time. Im in the UK.
Thanks
Kieran
    Dec '16
    Oct '17
  • 5
  • 3.5k
  • 5
Doesn’t look like that board is readily available, you could use one of those all in one ramps boards you find on eBay there about £35+ (make sure it comes with the driver boards)… but you’ll have to configure the board (marlin) you’ll need to know things like how many teeth the pullys have on the gantry’s and what type of thermistors as well as the diameter of the threaded rods used on the z axis. What’s wrong with the USB did you damage it while unplugging a cable or something ? Might be easier just to get the USB socket changed on the board you have.
Ramps uses thermistors for the hot ends not thermocouples so you’d need to swap those too.
Suprised at the OP’s need for USB - I always print from SD.
4 months later
I had a problem similar with the USB port Atmega8u2 is not detteting USB controller on my PC I test also iin another PC same issue, can I just order a Atmega8u2 and replaced? our most be flashed? Can I fix the damage one??? any tutorial
6 months later
