Oct 2015
If you have an address send me over a message on here and I’ll post you replacment ones free cut to size all you need to do is remove the nozzle and slide this tube in and out the nozzle back on
Hi Dan,
Is it possible to purchase some of this tube of you as I have 3 printers down at the moment and am waiting for some from china which seems to be taking forever or do you know of a supplier in the UK?
Thanks for your time
Tommy
i have bought the tube, seems to fit well and i havent put it all back as im using the left extruder for now lol
I wrecked one of my teflon tubes, too. I bought a 5-pack of replacement hot-end barrels off Amazon but they had 4mm OD PTFE linings in them, and a lot of stuff just printed too differently for my taste. (PLA and ABS seemed to print fine, but PETG-- my bread and butter material --didn’t print right anymore.) Either due to the different barrel design, or additional thickness of teflon…
I finally just bought a meter of 3mm OD PTFE tubing and waited like a bloody month for it to arrive from Malaysia via slowboat while I used the lining from the left extruder to get the right one back up and running. Taught me an important lesson though; stock up on replacements of anything that can take down your printer!!!
Also, stay away from PFA. It’s supposed to be rated for the same temps as Teflon and it was easier to source in the right diameter, but if you take it up to 240°C to print PETG or something…it’ll LIQUIFY. Not melt or deform, LIQUIFY. (Invented some new curses for that one, I did.)
