Very new to 3D and have a relatively new Creator Pro I received in “Open Box” condition. Sailfish 7.8 and the lastest FlashPrint.
When I try to level the platform or print, the platform rises to the top and hits the extruder heads without stopping. The adjustment screws appear to be fully tightened. In the Utilities\Home Axes menu the Z axis was originally set to 0. I tried changing that to a minus value but the issue didn’t change. After several print attempts I can’t get into that Axes menu now, since when I attempt to do that, the printer tries to print the last job and will run the platform up into the extruder heads again if I don’t stop it.
I have been able to restore to Factory Defaults and even reflash with Sailfish 7.8 from FlashPrint. Even this though doesn’t clear the last print job and the platform does it’s suicide thing if I try to access the Axes menu or print anything.
created
May '19last reply
May '19- 3
- 1.5k
like
