Jun 2017
Hi everyone, I’m really sorry if this has already been answered but I’ve searched all over for an answer to my problem but I am unable to find a solution so I’m hoping I can find someone here who can help. I’m new to the world of 3D printing but I have been a long time fan, I recently purchased a Creator Pro, and I was very excited to use it, however I have had no end of problems, I was able to print the test box in ABS however with a bit of warping but after messing around with the plate level I was able to correct this. Now however when I print with ABS it bunches up around the cog, I’ve cleaned it I’ve stripped it out I’ve done everything I can think of, I’ve printed at different temperatures nothing seems to work, the print starts of great then half way through it stops yet continues on as if it were printing. I’m at my wits ends if anyone can help I’d really appreciate it. Sorry for the long post, I’ve attached images to show what the print is like and the inside of the machine.
    Jun '17
    Jun '17
  • 8
  • 2.0k
  • 6
Have you tried another filament brand to see if it works… what temp and speed are you set at?
What temps are you printing at? Did you change filament manufacturers, does it do that only when you are trying to put plastic on the build surface (i.e. Can you extrude material when the bed is lowered and you are just loading filament) have you tried pla? Could be a bad batch of filament
Thank you all for your replies, I’m going to try what you all have said and go from there and will
update you all on my first successful print lol thanks again.
