Sep 2018
Hello, nice to meet you all, I am new on this forum.
I bought a creatbot D600 last week, and I have a really hard time to make it work properly. I humbly require your help to resolve this mystery.
-The problem : As I do with every new printer I get, I try to print the 3Dbenchy 20, in PLA, with a 1.75 mm filament, and a 0.4 mm nozzle.
-The main issue is : at one moment during each print, the filament gets stuck in the nozzle, resulting in a quick underextrusion then no extrusion at all (pic n°1). When I remove the filament from the extruder, I can see it is gnawed by the filament feeder (pic n°2).
- What I tried :
I am in contact with a Creatbot engineer since the beginning, but his advices have been… unconclusive. I should have used creatware (the creatbot software, but the installer available online is infected with a malware… so if somebody has a clean up-to-date installer, I am interested), so I use the last version of cura, with custom printer.
Temperatures : I tried a range of extrusion temperatures from 210°C to 240°C.
Retractation: I put 1,5mm in the beginning, then removed completely retractation.
Speed : I tried 20 to 50 mm/sec.
Flow rate : 80% to 140 %
Compression nut : I tried to tighten it and untighten it.
Manual extrusion : No problem when I extrude the filament with the panel.
Shell : 0.8 mm
Top/bottom : 0.8mm.
Layer : 0.2 mm
Whatever the parameter, the result is similar. (sometimes, the filament is stuck even after the first layer).
I don’t know if you require more data. If so, just ask me. :slight_smile:
I hope you can help me to solve my issue. Thank you for your time.
PS : Sorry if there are mistakes, english is not my native langage. :slight_smile:
5 months later
Sorry, could you solve the problem? i buy my first 3d printer last week. Its a createbok DE Plus, and im having the same problema.
Sorry for my english. Im from Argentina.
Hi RGarcia,
Just saw your message. I have three Creatbot DE-Plus and one DE models and like them a lot. They are all printing literally every day.
What exactly is your problem. What material are you printing and what are the settings that you use.
Hi, thanks for your answer.
I trying to print with differents types of PLA.
I change a lot of parameters…
Temperature from 190 to 220
Flow 90 to 110.
Z off set from non adderence to nozzle plugged.
I have a lot of problems…
Thickness of each wall its different. Expected 0.4 get in same cubre 0.44 0.45 0.44 0.47 (not always same value).
Cube height, not as expecter (10mm) i get 9.7mm 9.8, 9.9, etc. never 10 or more.
I buy machine with auto lvl, but try to lvl plattaform (goes to x0 y0 and adjust with nozzle 1) When i finish all corners, i align nozzle 1 with nozzle 2 (only mode second nozzle)
Change 3 fillaments. orange PLA, silk pla and green pla.
Use speed from 20mm/s to 60mm/s
Change jerk (the corners are not well defined) from 15 to 10 and 5
fan speed from 0.1 to 1mm and 50 to 100%
etc…
I move 1 parameter each time… i did at least 100 different tests…
Best results for calibration cube:
Layers 0.2
Extrusion width 0.4
Perimeters 1
flow 100
top layers 0
botom 0
fill density 0
print speed 30
temperature 200
bed 50
support none
advanced:
retraction speed 20
distance 3mm
(ill try + and - retraction values)
inithial thickness 0.3
i. flow 100
travel speed 70
botom layer speed 20
solid layer s 100
outher wall 80
inner 100
infill 105
ill use createbot cura and ultimaker cura… maybe im not configuring ok… because its my first time with 3d printing… but i dindt figure what change now… ill try with all the parameters that i see…
Could you help me?
maybe i can send pictures from my cube or another model…
13 days later
4 months later
Sorry to hear that.
Do you have the 1.75 or the 3mm version?
And what are the difficulties you are experiencing?
5 months later
Hello Rgarcia,
Did you have to change the extruder to for 3mm filament? I am having the same issues so I order the 3mm filament and it doesn’t fir the extruder.
