Snoopy
ok i need help. no matter what settings i change theres still a gap between each layer.
its not a clog and iv been using the same fillament as i have been using before. it randomly started between a print about a day ago. the same day i had printed about 3 other things but during 1 print half way it just stopped printing right and started printing like this
Please help
the image
Lets start with software and is your bed leveled?
Jim_12
Looks like your printer is under extruding. If it happened during a print I think we can eliminate software. Or your hotend is clogging up or maybe your feeding extruder is not working properly anymore. Did you check all of this?
I agree it looks like possible under extrusion but also looks really hot.
Really need more info. Slicer, material, temps, speeds etc.
Olsen33
What 3d print software do you use? Try leveling your bed again.
Olsen33
6
Depending on software it might be a retract prime issue. Also in craftware their is a z position that i moved up .200 micron it helped with stringing. I use pet-g to print with.
