Go to the Edit menu and select Make Solid. It will default to the Fast method and will show you a preview. If it looks OK, click Accept and you will have a new solid body and the original mesh will be hidden in the feature tree.
If the solid isn’t good enough, you can try the Accurate method, click update to see what the solid will look like. You can adjust the Solid Accuracy, Mesh Density, etc. until you get a result you like, then click Accept.
See here for more info:
http://www.mmmanual.com/make-solid/ 383
There’s more to it than I explained here and I am learning as I play with the software. Unfortunately the documentation is pretty sparse.
