Nov 2017
I have a duel extractor CT’c makerbot replica and have a control board problem. The com port no longer connects to the computer so can no long printer to it!!! so I have 2 questions and hope someone can help me?
1). where can I buy a control board, I’ve tried looking on Ebay and found boards for lots of other printers but not for the CT’c
2). There is a SD slot for printing from a memory card but it only seems to print from .x3g extensions and I use Autodeck 123D and that only produces .STL, .x3D or .gcode so does anyone know how I can produce or convert to .x3g I’ve tried changing the extensions to the correct one but the printer .just ignores them!!!
The last thing I want to do is buy a new printer as I’ve only had this one for 2 years
Thanks
Dennis Gorringe
    Nov '17
    Nov '17
  • 6
  • 1.6k
  • 4
Haven’t been able to find a board that fits the look of my board, so have abandoned that idea for the moment and gone for the cheaper option of getting the printer to work from the SD card ! limited success on that front. I’m using GPX with GPXUi to add the command lines. My new problem is although it produces the .x3g file required, the printer doesn’t respond properly or the file doesn’t come across properly! or I’m not using it properly! The head and build plate go to the correct start position and the extruder and build plate heat up to the correct temperature, once the correct temps have been reached the build plate and the head moves to the build start position and that is where it stays. no extrusions, no x or y movement I know its nothing to do with the stepper motors as they work correctly on other functions of the printer > Anyone got any ideas as to where I’m going wrong
Dennis
