Feb 2016
You always purchase merchandise from Amazon, Ebay , Aliexpress, Bestbuying, or Gearbest? Have you found that almostly 3d printer selling on these B2C supermarket are cheap prusa i3 printer, except Amazon? why and what is the reason. People lack of money in this period of economic depression. Or people keep in mind that 3d printer is a joke to print what you want, small ones is enough to do some work. I think big machines selling faster at Amazon than other shop is the rules of Amazon and people’s deep-rooted thinking method.
Now, for a new product at Amazon UK, you also could find JGAURORA A-8 as a big size and affordable 3d printer. Here is the details below:
Main Features:
● Can be used for printing different items like big machined part model, portrait etc.
● Metal steel material, more stable and durable.
● Using well-designed MK8 type extruder, high quality dual stepper motors to feed the filament automatically to the nozzle, more convenient.
● Precise ball screw rod, positioning accurately.
● The high strength and accuracy of structural parts to ensure the quality of printing models, as well as the working life and stability.
● Rotray operation, adjust the printing speed and temperature freely when working, more convenient.
Specifications:
Brand: JGAURORA
Model: A-8
Printer type: FDM business type 3D Printer
Frame material: Sheetmetal
Extruder quantity: 1
Printing size: 350 * 250 * 300mm
Layer thickness: 0.1-0.3mm
Sd card off-line printing: Support
Printing speed: 20~100mm/s
Nozzle dimeter: 0.4mm
Nozzle temperature: Ambient temperature~250 degree
Hot bed temperature: Ambient temperature~110 degree
Hot bed material: Aluminum sheet
XY axis positioning accuracy: 0.0012mm
Z axis positioning accuracy: 0.0025mm
Printing material support: ABS, PLA
Printing material diameter: 1.75mm
Software language: Chinese/English
Date import format: STL, G-Code
Input voltage: AC 110-230V (adjustable)
Output voltage: 24V
Operating system: For Windows, for Linux, for Mac
Printing control software: Cura
Working condition: Temp: 10-30degree, humidity: 20-50%
Power plug: US, AU, EU, UK (optional)
Machine size: 590 * 450 * 570mm (L * W * H)
Machine weight: 32kg
Packing size: 700 * 570 * 680mm (L * W * H)
Packing weight: 36KG
Packing List:
1 assembled A-8
1 tool kit
1 Maintenance Manual
Tool Kits as below:
◆ 8G SD card(G-code files for testing)
◆ Trial filament*3m
◆ 1*M8*10mm wrench
◆ 1*Cutting nippers
◆ 1*USB line
◆ 1*4mm/3mm/2.5mm/2mm/1.5mm hexagon wrench
◆ 1*filament holder+4*M6*10 screws
◆ Power supply cable
◆ 1*SD card reader
◆ 1* HBG glass
◆ 2*finer needle to poke the extruder in case plugging
http://www.amazon.co.uk/gp/aag/main/ref=olp\_merch\_name\_1?ie=UTF8&asin=B0177YHPMW&isAmazonFulfilled=0&seller=A1EEWZOWEZCL5J
Chinese Version video for your reference: http://v.youku.com/v\_show/id\_XMTQ3NjYzMjgyNA==.html?qq-pf-to=pcqq.discussion
All Rights are reserved by Shenzhen Aurora Technology Co., Ltd.
