Jan 2016
hello!I recently bought a ctc dual nozzle printer. I really don’t have much experience in the field but I 've searched many manuals and I can’t find why does my printer sticks to the right side of the axis and starts clanking…If anyone has experience the same problem please inform about what can I do!
    Jan '16
    Jan '16
  • 7
  • 922
  • 4
Hi! Could you elaborate on what you meant with “sticks to the right side of the axis”
this be the X or the Y axis?
“clanking sound” sounds like the servo slipping, skipping teeth?
If you move it by hand, can you feel any friction? Does it sieze anywhere?
Sounds like the x limit switch is not working does it get pressed before hitting the right? Does it stop before the end if you push it you could try reseating it at each end note they are normally hot glued it. Also the wires for the x-axis are known to break because the are not flex rated and are run in a weird way. Once it’s fixed look into a cable chain for the x-axis.
Agreed, this happened to me because my limit switch wasn’t even being “engaged/pressed” after upgrading to new extruders.
Well yes, there was a problem with my limit switch after all!Since I αmend that everything works fine!!thank you all!
