Mostly yes, expect longer print times for the same model size though, and ensure all settings are in fact correct. I have however not really noticed much difference (except for the time) between my 0.4 and 0.2 heads on the Kossel mini. I also found that you can’t feed filament as quick as with the bigger nozzle, but that may be just my personal experience and not necessarily the norm.
Actually, I just changed one of my nozzles last night for the first time, from .4 to .25. I have a MendelMax 3 Dual, with E3DV6. I designed a small part for a friends Dremel grinder, and needed the smaller nozzle for the fine detail of this part (a 10.4mm dia spline). Followed the E3D wiki directions: Loosen heat break, heat up to 285C (pulled filament @ 235C) , Remove nozzle, install new nozzle and tighten, let block cool, tighten heat break.
In S3D, changed nozzle size to .25, manual width to .25. Printed a 20x20mm cube, single wall, no infill or top. Wall thickness came out to .29, so I set width to .29 and printed my part in natural PETG at 75% infill, .200 layer height. Part seems to be great.
Nice. I am doing the same idea. I have some small simple parts (bushings) that print ok with the .4 but I am wanting to see how they print with a smaller nozzle and how easy the change goes.
The nozzle simply unscrews and the new one screws on. I haven’t changed mine yet, so I can’t say it’s easy for sure. It seems like it woudn’t be a problem, I mean the E3D is designed to be taken apart and nozzle changed easily…definitely just follow the directions.
Smaller nozzles exponentially increase print time and are more prone to clogging. You shouldn’t have to print slower but depending on the material, it is sometimes helpful to slightly increase temp to keep the material flowing through the smaller hole. I constantly change nozzles and even mill my own for special purposes. The nozzle should be matched to the smallest feature on the part. I also print a lot of parts with very thin walls, so matching the nozzle to the proper shell with is also very helpful.
The more effort you put into initial calibration, the less trouble you will have when switching nozzles.
-Jesse
Thanks, I always level after any changes. Easy enough to do and habit now! Good to think of though to lower the bed in case it is a bit lower when starting up.
Take care to change nozzle heating it to a temperature that can melt your material and verify bed leveling of course… Then, in your slicer, set new nozzle diameter, suitable temperature, speed and so on.
Based on my experience, the nozzle diameter force to reduce the height of the layer (usually half of the nozzle diameter. If you keep for example the layer height to 0.18 with nozzle diameter of 0.2mm, there will appear some cut on the wall surface, due to the fact that the touching conditions of the “tube” is minimal. At least this was happens to me with ABS. Therefore I came back to 0.4/0.6mm if I don’t have specific need of high accuracy. Hope this experience could help you.
