I installed a Flexion dual extruder on my flashforge creator pro. The distance between the nozzles must be greater now because when I tried to make a print using ABS material with HIPS support, the support and the model were not lined up but rather offset causing them to overlap. Is there a way to change the distance between the nozzles in Makerbot desktop or would I have to use a different slicer software?
Here is a picture of the print. Ignore the top bit, the print came loose from the build plate at the end.
https://imgur.com/a/lQCk2fv
