Dec 2016
I have a FFCP that has what appears to be a bad controller board. One of the end-stops will not work and I’ve swapped the actually end-stop and the cable and it still doesn’t work. The LED will not turn on when the switch is pressed. So I guess it’s a problem with the control board itself.
I haven’t priced the Qidi board yet, but direct from FFCP is around $180. If the Qidi board is significantly cheaper, will be work as a direct replacement with no other changed needing to be done?
    Dec '16
    Jan '17
  • 4
  • 604
  • 3
I am thinking it could but I also think QIDI uses a modified version of Sailfish but even that may not be an issue. Depending on the cost it may be worth a try. You could probably sell the QIDI board if it didn’t.
Do you know of any US suppliers that may would have that in stock instead of ordering overseas?
Check QIDI on eBay and see if they show any shipping from the US. Also check with them directly for speedy shipping cost. I bought a new bed heater board and had express shipping for $18 I think it was and it was pretty quick.
They are working on getting more available to ship from here.
Also a google search, maybe someone else has it at a good price.
