Nov 2015
Sorry for the bad picture quality.
I’ve recently started getting these bumbs on my prints. Seems to be happening the most on non overhanging top surfaces.
I am using a lulzbot Taz 5
Print bed at 110C
Nozzle temp at 235C
50mms print speeds.
40C enclosure
IC3D filament
Am I extruding to cold? Seems to be slightly (only slightly) better when I put the nozzle temp up to 240C. Bad filament?
I Should also note that it seems to be worse on long passes. In other words, small parts being printed that only extrude a little bit here and there dont seem to be showing signs of this. However when I print something like the imperial star destroyer at 10" and the nozzle literally extrudes in a straight line for 10 inches… this issues shows up.
Thanks for any help.
    Nov '15
    Mar '17
  • 14
  • 42.0k
  • 12
It looks like over extrusion. Check the diameter of your filament, 3mm filament should measure about 2.85. There is a setting in your slicer to set the actual filament diameter. I’m guessing that your filament is actually a little wider on average so you are over extruding. You will need to check the diameter in several spaces.
Another option would be your retraction amount is too much, causing the extruder to sit in one place for a moment to retract the filament.
If it is one bump per Z Axis level, then check your retraction. If it is random, check your filament diameter.
Happy printing fellow Taz user.
9 months later
Your problem sounds very similar to mine: bumps showing during circular cross sections only of print using black filament. Ive attached a cropped photo of the problem. It seems like it’s on nearly every layer, but never in the same spot. After some observation I think that a print head pause is the problem in my case as well, but I don’t know how to change that! Have you found a solution?
(I’m curious to try the same print in another color, because after hearing a Schnaab’s comment on the black filament I realized that I don’t remember seeing this problem outside of my black filament)
please let me know, Thanks!
Lulzbot TAZ5
Print temp: 240C
Print speed: 35-45mm/s
Material: Village Plastics ABS
8 months later
