Nov 2015
You may also want to try a different brand of filament. It could be a quality of filament issue.
9 months later
Your problem sounds very similar to mine: bumps showing during circular cross sections only of print using black filament. Ive attached a cropped photo of the problem. It seems like it’s on nearly every layer, but never in the same spot. After some observation I think that a print head pause is the problem in my case as well, but I don’t know how to change that! Have you found a solution?
(I’m curious to try the same print in another color, because after hearing a Schnaab’s comment on the black filament I realized that I don’t remember seeing this problem outside of my black filament)
please let me know, Thanks!
Lulzbot TAZ5
Print temp: 240C
Print speed: 35-45mm/s
Material: Village Plastics ABS
8 months later
