See craigslist post for photos - http://seattle.craigslist.org/see/ele/6036847133.html
Must pick up the printer in Ballard.
Previously used for printing 3D shoes at Pre-volve.com 1
Minor maintenance required: mechanical movements need tweaking.
Otherwise printer is in great shape.
Product Description:
The print volume of the Builder Premium Medium Dual-Feed is rare when comparing it to other 3D printers. With a maximum build volume of 210x210x400 mm it’s the perfect 3D printer for bigger objects and prototypes. The 4.3 inch full color touch screen, with integrated Wi-Fi, is located on top of the Builder for easy access. The touch screen makes it really easy to control the Builder and heated bed. Printing while you are not at home/the office? Use the on-board camera to check the print and control the Builder with your mobile device. The Builder Premium Medium comes with the unique Dual-Feed Extruder which Builder 3D Printers is known for. The Builder Premium comes with 2 spools of Builder PLA, free color mix code, a spare nozzle, spare teflon tubes, tools, quick start and manual.
Specs:
3D Printer dimensions:
370 x 380 x 710 mm (LxWxH)
Certificates
CE certified
AC port
100 – 240 V / ~3A / 50 – 60 Hz / 120 Watt
Frame
Steel – powder coated
Weight
24 kg
Connections
USB, Wi-Fi (strong Wi-Fi network required)
Full color screen
4.3 inch
Camera
480×272 pixels
Email Steph@pre-volve.com if you’re interested in buying the printer.
