A Challenge!
Marvin in colorfabb Bronzefill.
The issue with this filament is that it has “tighter” envelopes with regards to speed, temperature.
I had to print it 3 times to make it nice:
After first print I had to reduce resolution from 0.06 to 0.1mm
layer height. Also had a temperature drop in the beginning (Check Legs!),
due to FANS full 100% , and not gradually. Avoid that!
Then the ring on top looked completely melted,
Second print lower temp: 205.
Then it fused so badly so the ring broke off for nothing in post processing.
Successful attempt:
Printer: UM2, with 0.25mm nozzle and custom heater block upgrade.
Bed: 60, no tape or glue but clean glass.
Layer: 0.1mm.
Initial print temp: 225 (sticks much better)
After few layers temp: 215 (!)
Fan: FULL after first few layers.
Fill: 30%
Filament: colorfabb Bronzefill
Speed: 30mm/S (Cura at 50 default, and UM2 at 60% = 30mm/s)
Layer: 0.06mm
Final print, No Processing
created
Feb '15last reply
Feb '15- 22
- 3.0k
likes
