Nov 2015
Which are the better temperature and speed for PLA?
I tried from 180 to 240°C, but if the temp is colder the PLA doesn’t cool down, if hotter it cools too much…so i changed the speed, but i don’t find the right relationship temp-speed, help help help :slight_smile: thank you very much
    Nov '15
    Dec '15
  • 6
  • 37.8k
  • 4
Hi Gianfranco!
Maybe you must polish the nozzle, it can be obstructed.
It can be also a problem of the pusher tag block which must be regulated.
Let me know :wink:
Hello!
The PLA it can print at 210-215 ° while for the speed 35-40 mm / s .
With these settings it prints well, but depends on the quality of the PLA .
The only solution is to try , try and try again !
Thanks. I tried to print from 180C to 240C…180C it’s impossible to print even with low low low speed, over 200C i start printing but with low speed, if i want print at 80mms i must set the temp at 230-240C! Maybe i have to change the PLA? And the surface isnt smooth, but i see all the layers on the surface.
All the set-up is well done. Thanks. I tried to print from 180C to 240C…180C it’s impossible to print even with low low low speed, over 200C i start printing but with low speed, if i want print at 80mms i must set the temp at 230-240C! Maybe i have to change the PLA? And the surface isnt smooth, but i see all the layers on the surface.
