do you know, by any chance, a filament provider that propose a better price than what I’ve found untill now :20€ for 1 Kg of white ABS (shipment not included). If you do, please talk to me about it (prices, quality, minimum qantity order,etc…)
Thank you for your info!
Jonas
s
@Brian @ProdPoint @Luuk any idea?
Filaprint have some deals on at the moment, 16euros for 1kg, from my experience their filament is pretty good.
http://shop.3dfilaprint.com/bargains-25-c.asp
You could also have a look on Alibaba if you’re considering buying a few at a time, you can find 1kg for as little as 8 euros.
Although it’s worth remembering that at those price you might find that the printing quality can be dissapointing.
Ps: Unless you need that extra strength I hightly recommend PLA
Thx a lot!
On my point of view, filament cost around 25€ / kg is sufficient. Lower prices will sometimes (not everytime) impact quality.
I want to be sure that the filament is not the cause of a bad print.
In fact, 25€/kg is not really an expensive price if you consider that a part uses very few material.
My consideration goes on material choices (colors, material type, … ).
If you consider lowering the spool prices, you should look at pellets and do your own filaments.
Hi Jonas - Cheap 3D Filaments ships 29.00 USD. Tested in over 20 printers by 1000’s of users. Check them out: http://cheap3dfilaments.com
thx I’m checking it right now!
