Mar 2015
Hi Adriana,
The issue is not if the extruder have enough power to pull the filament, because it has :wink:
Like Arnoldas said, you can´t adjust the BEESOFT settings yet, so it would be best for you to use tested filament by beeverycreative on your beethefirst. The BEEs will probably release a BEESOFT version in the future in which you will be able to adjust settings, e.g., temperature.
But if you want to try it anyway, use the “black” filament settings on BEESOFT. I gather this is the best profile when you want to try other filaments. :wink:
Hi Sergius!
I will try the black filament settings and let you know how it goes :slight_smile:
Could it be possible that temperature on BTF is not stable throughout the print? What seems odd to me is that it does a good job at first, meaning it is perfectly capable of processing the plastic. Maybe the temperature drops down at some point during the print?
I think the temperature at the extruder is stable, but the temperature of its surroundings is not.The area around the extruder can get hotter during the print and the temperature affects the PLA, and this could jam the extruder. You can also try to take off the top white cover of the printer in order to cool down a little bit the extruder area. :slight_smile:
Hi Sergius!
I took off the cover and it did a little better, it almost finished the job! but then it stopped again :frowning:
Without the cover I noticed the extruder wasn’t exactly “jammed”, it was more like it cooled down and the filament wasn’t melting anymore. Next step is find a way to keep the temperature higher, as suggested by @derKarsten, hope it works!
Colorfabb’s website reads that they have tested their pla-pha on BTF, I guess it has to work somehow.
Thank you guys!
