i have an x-one2 printer and don’t seem to be able to properly set the build plate temperature. i bring it up to 100c and hit the print symbol and it starts to print and at the same time the heater in the bed plate seems to turn off and as the printing continues the temperature of the bed plate keeps going down. is this the way tis printer works or am i doing something wrong. help!
Bed temp like extruder temp is set in the slicer. You shouldn’t have to manually turn on the bed heat.
What slicer are you using?
thank you so much!! i have a long way to go.
Milkdud
The X-one doesn’t have an enclosure/plexiglass so the temp of the bed will go up in down unless you find something to enclose the printer with to keep the heat in I’m also guessing since you have the bed set to 100 you are printing ABS and you will need to enclose with this material or it will warp
