I have printed a solid part in the cr10 5s, with the cura software, I used 71 layers of 0.1mm for a total z print size of 7.1mm, I used top bottom thickness 0.6mm, infill density 100%, print speed 60mm/s, travel speed 120mm/s,printing temperature 195 deg, bed temperature 60 deg, Brim 2mm. The problem it that it comes with a height of 4.55mm instead of 7.1mm, the dimensions on the x and y are perfect and the part looks good, what can be the problem?
