Here’s your chance to own a brand new, never used, assembled B9Creator.
The B9Creator is a powerful tool that allows users to print as creatively as they design, producing high-resolution models, prototypes, and working parts.
The B9Creator is a DLP (digital light processing)-based printer. DLP is a similar process to stereolithography in that it is a 3D printing process that works with liquid photopolymers. The major difference is the light source. DLP uses a conventional light source to project an entire slice/layer of the model being printed, making it faster than laser-based SL, which traces the cross-section of every model on every layer.
The original B9Creator V1.1 is perfect for those who need one tool versatile enough to print the finest details but can build projects as large as belt buckles and bracelets. Designed to offer a high level of user adjustability and control with low operating costs for shops who want to integrate 3D printing into their business without spending a fortune. Ideal for jewelers, artists, universities, model makers, prototyping/manufacturing and hobbyists alike!
CONDITION:
Brand new, never used. $3500 0B0 (printer assembled & shipped). Includes extra accessories & materials as listed below.
INCLUDES:
  B9 Creator 3D Printer v1.1 (with included upgrade package)
  Extra heavy-duty bed/vat
  Electrical adaptors for various world zones
  B9R-1-RED Resin – 2.2 lbs (1 kg)
  Maker Juice Pigment
  Sylgard 184 Silicone Elastomer Base & Curing Agent (1.1lb kit of Sylgard 184 encapsulation kit; 10:1 mix ratio)
  2 UV nail lamps for post curing
  PDF instruction manual available online
SOFTWARE:
The software to operate this system is available for DOWNLOAD DIRECTLY from the B9Creator web site. It will not ship with the machine so you will need to do this download!
BUILD VOLUME:
Build volume varies, depending on resolution. Resolutions in the x/y plane (horizontal) of 50, 75 or 100 microns are possible by adjustment of the projector’s position and focus. Resolutions in the z (vertical) build axis from 101.6 to 6.35 microns are possible via software selection. (The minimum z axis “step” size is 6.35 microns.) At the 100 micron x/y pixels setting, the build area is 102.4 mm (4.03") x 76.8 mm (3.02") x 206.4 mm (8.125"). At the 75 micron x/y pixels setting, the build area is 76.8 mm (3.02") x 57.6 mm (2.27") x 206.4 mm (8.125"). At the 50 micron x/y pixels setting, the build area is 51.2 mm (2.02") x 38.4 mm (1.52") x 206.4 mm (8.125").
Note above that the Z axis build height stays constant throughout the different X-y variations in resolution (206.4mm or 8.125").
3D PRINTER SPECS:
Weight: ~30lbs (13.5 kg).
Height: 31″ (79 cm)
Width: 18.5″ (47 cm)
Depth: 12″ (30.5 cm)
ACCESSORY SPECS:
Weight: 23 lbs
Dimensions: 18 x 12.25 x 12 inches
BENEFITS:
DLP technology exposes an entire build layer at a time, total build times for most objects is normally between two to five times faster than other comparable technologies. Another unique advantage of this system is that the output resin, unlike that of photo-polymers in general, is proven to be directly castable when cured properly.
Well if you read to this point, then you can read. I might have left something (not sure) but you can send a mail at Renlaz@pm.me for Inquiries. Thanks
Hello Everyone, Seeing my ad once again and I realized they was a little miss communication, The retails price for a brand New B9creator v.11 3D printer is $3500( there about). I also realized I did not add my asking price and that $1900 OBO. Thanks
