Just started to assemble Anet A8, not got very far but I have a question.
It’s about Part #1700300002 - Y Axis Belt Bearing Support
This comprises two acrylic sides, a nut and bolt that form an axle and two metal wheels which I assume will create a roller for one of the belts.
The two metal wheels have a bearing inside so I’m assuming that once assembled the wheels/roller are meant to rotate freely.
My dilemma - if I tighten up the nut and bolt the acyclic sides clamp against the wheels stopping them from turning. If I leave the nut and bolt loose then the wheels turn but I guess over time the nut and bolt will work apart.
Assuming the wheel/roller is meant to rotate freely I can think of two approaches
1 - Leave the nut and bolt just loose but add a locking nut to stop the assembly working apart
2 - Insert small washers - the diameter of the inner of the bearing - and tighten the nut and bolt. The washers should keep the acrylic sides off the wheel outers allowing them to rotate freely. Even with this I would be tempted to add a locking nut or use threadlock.
Anyone else encountered this and how did they solve it?
And in general do you use threadlock on all the nuts and bolts - given how much the printer will move and vibrate it would seem a good idea to me but you guys may know better.
Thanks for the help,
Nigel
created
Sep '17last reply
Sep '17- 3
- 1.1k
