Jan 2017
Hi all,
Getting ready to try some nylon. Looking for any advice including brand and where you got it. I am in the US so that will factor in on a vendor I guess.
Printer will be a Flashforge Creator Pro with Micro-Swiss all metal hot ends.
Taulman 230 is the easiest to go nylon wise. It is a blend, that prints similar to PLA, so that is nice.
There are really two issues that you will deal with re:nylon.
Getting it to stick to build platform–> Glass with lots of Aquanet Super Hold.
Stringing- re retraction settings.
But both are doable.
Thanks Perry, I’ll look at that. I am using a PEI bed at the moment so will see how that goes but have the trust Aquanet standing by!
It’s time to broaden my horizons on materials a bit!!
I bought some Taulman filament from Amazon. It popped and sizzled when it was printing. It had water in the filament. I took the roll to work and put it in the welding rod oven for 3 days. The welding oven maintains a temp of around 95 C. The filament prints much cleaner and better. No popping and no sizzling. The color did fade and the spool warped but the filament was OK.
I read something on nylon that it can absorb its weight in moisture in 24 hours. It also said you really need to dry it before use.
Yeah, it popped and sizzled right out of the bag. I read reviews on Amazon with the same issue, but decided to take a chance. My buddy ordered a roll a few weeks later with the same issue. And yup its taulman. The original clear color faded to yellow.
