I have .STL models for an anti-vibration case for IMU. The case is composed by two parts connected by damping-balls, the IMU is attached to the upper part. I have to 3D print the models but I need an advise about the best material to use. Consider that the base of the case have to be screwed to the chassis of a drone/rover, the surface of the case itself have to be printed with small tollerances and possibly be levigated.
Thanks
I offer over 30 materials and have worked on many similar projects. If you want to contact me at my hub and give me some more info I can advise further.
https://www.3dhubs.com/miami/hubs/mindfull
-Jesse
