Dec 2018
I have been printing with my printer now for about 5 months and I have been getting some nice prints, I did have a bad wire problem on the hot end fan and repaired that, however lately I have been getting a lot of vibration from the y axis. I have over 1000 hours on the unit now and the problem has just cropped up and seems to get worse with each print. I have disconnected the belt and checked the belt is good the bed slides freely so I believe the bearings are good. I checked the wiring and all connections seem to be fine so now I am stumped. The X axis motor is almost silent when it moves but the Y axis is very loud.
Has anyone else run into this problem, I could really use some help on this
Thanks
19 days later
Hi sorry to jump in this as well :see_no_evil:
Not sure if you manage to find a solution to your issue …
So I have the exact same problem. Printing fine for months. Recently upgraded to a glass bed. First print after the glass bed was pretty decent
Then all of a sudden my bed has a stutter like movement but only on the right of the bed.
I disassembled everything bed related …checked both rods are straight, tried drylin and stock bearings, they glide smoothly over the rods.
Stepper seems fine, everything is aligned. Stepper is not under strain, no weird sounds!
When homing or moving y axis with octoprint or marlin there’s no issues y axis performs normally. This only happens when printing!
Any advice would be appreciated. I doubt it’s software related as I havnt messed with jerk settings etc … tried older gcode files to ensure it’s not gcode/software issue
Im a little confused on this.
You say it is happening only on the right side of the bed.
Im guessing you are seeing the stutter on the right side of the bed?
But everything is aligned…
Do your rods fit perfectly, or do you have space where the rods can move backwards and forwards a little inside the rod holders with the caps over them?
If you move the bed back n forth, can you hear the rods banging inside the caps?
Mine did, I had to put some paper in there to make it quieter.
I also found with mine, that I had to loosen of the bearing holders to the plate, and run the rods back n forth a few times to get them perfectly straight. Using a straight edge did not help me at all. It was easier to loosen them off, and tighten them up to the point where the bearing holder could move, but with a little force. Move the rod back n forth a couple of times after tightening each screw to ensure that the holders arent moving too much from the tightening of the screw.
It was a pain, I also found after all that fiddling that the distance between the rods in the igus bearing (much lower tolerance to error) was off by about 5 mm when the rods were extended. So this meant I had to loosen the whole plate sections together to get it all to line up correct.
Its exhaustive the steps you have to go through, especially with the igus bearings. But totally worth not hearing the original bearings clatter and the quality of the prints jump right up when you do get it sorted.
As a side note, also check that your threaded rods and nuts havent come loose and that the distances over them to the front to rear braces measure the same. Any movement here would cause weird warping and who knows what issues…
Hope this helps, Im only really able to give you answers from my own experiences, and I went through a very tedious time with my anet upgrade to igus, but now it prints fantastic.
DJ
So my problem got more complicated
I removed the bed and went over all connections to make sure they snug and then removed and replaced the bearings with Drylin bearings.
The bed was smooth, could give it a flick and bed would move to the back smoothly.
Proceeded to re-install the bed and after hooking everything up it seems my Y axis is switched around
The bed doesn’t home to the endstop but instead to the front and because there’s no limit switch it just grinds violently and Marlin reports a homing error
For some reason … when I move the bed +10 the bed doesn’t move towards me instead it moves towards the endstop as if min and max have been reversed
When -10 it moves towards the front of the printer. -10 is all it can go tho. Bed doesn’t move thereafter
Checked belts are installed correctly. Stepper motor is correctly installed. Cables are fine.
When controlling via octoprint online interface. Front moves bed front … back moves bed towards endstop
When using marlin via the Anet display & buttons
Moving axis +10 sends the bed back towards endstop
Moving -10 bed moves towards front, away from endstop
I’m considering reflashimg marlin in the hopes that helps and I can go back and tackle my original problem with the bed vibrating… lol fun and games :slight_smile:
Thank you for your suggestions … not sure where to start now
