My Anet a8 stops printing after the bed leveling is done and is slowly moving down in the Z-direction. The G-code seems fine and trying different slicers didn’t make any difference. The printer LCD shows the M117 printing code, which is the last start code before the sliced G-code should be executed. Also printing from usb gives the same problem. The temperature from the extruder and bed is also stable, so shutting down the print doesn’t seem obvious. Does someone have a clue what the problem might be ?
Greetings,
Huub
