This is my first post. I recently finished building my Anet A8. I am running into an issue at the moment where the print will start normally, but within the first few min (2%) of the print the layers will get printed all over the build plate and not one on top of the other.
This is called layer shifting, Look it up on google you’ll find a lot of resources and info about how to eliminate that issue. Mainly, it is caused by the belts being either too loose or too tight. It could also be that your board is getting too much hot that the drivers are not functioning properly.
Good luck!
Looking at the picture… your X Belt is too loose. Sometimes the belt slips on the gear because it is too loose, causing your printer to think it is printing somewhere it isn’t.
You can still print with loose belts as long as you lower the printing speed ALOT (in case you want to print something like this 11 to help fix the issue).
