My Anet A8 v2004 LCD is way to bright and the brightness can’t be controlled from the firmware. I am therefore thinking of soldering in a different resistor for the backlight, problem is I can’t find a pinout anywhere, has anybody else already done this (or used a variable) to change the backlight level? If so what value resistor and which pin is the correct one on the display board?
