Hi. This forum needs a search! So, I don’t know if this was asked before. I just got my Anet A8 built and am on the 3rd video for calibration: - YouTube
First of all, my X starts tilted, meaning the right side is about 2-3mm higher than the left. If I adjust even by loosening the set screws and turning only the screw drive, then do “Home All” again, it still pulls the left lower. Not a big deal, I could make the bed a little higher on the right, but…
The real issue. In the video, the steps are Home All, adjust bed, home all, check bed. When they do Home All the second time you can see the Z go up just a bit before it comes back down, so it can “reset” it self to the switch. On mine, it actually trys to pull down again only and therefore the right side goes up even more (more tilt) and so I have to continually adjust the bed up over and over until there’s no more screw to undo on the bed.
Any ideas what’s going on? I think the Z stop is working otherwise it would just never stop trying to pull down the Z side right?
