I just changed my nozzle on my Anet A8 after it was fully used up. When I started printing with my new 0.4mm nozzle (same as before) my extrusion 8 was VERY bad and inconsistant, even so bad I couldn’t continue printing because it would pull the first layer off.
If I compare it to my extrusion 9 before the nozzle switch, it is really bad, even though I tightened everything as before. I am quite sure it doesn’t have to do with adhesion to the heated bed since I use tape with pva glue.
Any advice on how to remove this under extrusion so I can continue printing?
All the specs:
- 25mm/s first layer print speed
- 200C nozzle
- 60C bed
- PLA materia;
- 0.4mm nozzle size
Let me know if there is anything else you need to know.
created
May '18last reply
Jan '19- 3
- 1.7k
links
