Feb 2017
When trying to print with this printer the filament stops before the raft is complete.
I setup the machine properly (auto level, nozzle height, etc) Preheat the table to 88 C. Test the extrusion of filament. And then start the print.
The machine prints the test line and then starts on the the raft. As it completes the raft (about a 3"x4" raft) the drive motor for the filament starts to make a clicking sound and the filament flow slows. After about less than a minute, the filament stops. The nozzle and table both say 98% to 100% heated during this time.
So far I have replaced: the nozzle (twice), the heater, the perf-board, the filament (once with a partially used spool and a new spool, both ABS).
Any ideas?
    Feb '17
    Feb '17
  • 6
  • 3.2k
  • 3
I previously had an H480 which should be similar. It worked really well but it was really picky about the diameter of the filament.
I used the manufactures filament exclusively but I had a few spools that exhibited the same symptoms.
You did not mention a filament jam or failure to extrude after your failed raft but I suspect that is what is happening.
The clicking sound is usually the feed motor binding and stripping a spot in the filament. If you see this after you remove the filament from the head, and it has happened a couple of times you may need to disassemble and clean the filament drive gear. Where it makes contact with the filament the teeth can get filled with ground filament and then it is much more likely to fail the next time you print.
If if I was guessing at the cause and it is not a bad spool of filament. I would say there is a problem with the bed level sensor.
If the bed is too close to the nozzle it puts more pressure on the extruded plastic. This extra pressure can cause the symptoms you describe.
You may be able to do a manual bed level and that may solve your problem.
Good luck.
