Dec 2014
Hi Gareth & Gabriela,
With the heat involved, plastic is definately not going to be feasible, but we can 3D print a pattern and then cast the part in brass or aluminium (if weight is an issue).
As Andy mentioned, the part looks simple enough to not warrant the additional expense of scanning. The CAD model needed to produce the 3D printed pattern can be built by measuring the original part.
We have all the equipment in-house to reverse engineer and produce the final part, so if you’d like to proceed, send some photos showing all sides with some overall dimensions plus any dimensions of critical features that will allow us to assess feasibility for our processes.
kind regards
Ian Carter
Impossible Creations
