Dec 2018
Can you show pictures of it not extruding properly?
Not extruding for the first few seconds is normal; the plastic leaks out as it’s heated, so the extruder needs to “catch up” in a sense - this is what a skirt is for, it helps prime the nozzle before the actual print begins.
Depending on the buzzing sound, this could be a misaligned fan which happens quite frequently with cheap ones. Sometimes simply lightly stopping it and allowing it to spin up again can help.
