Dec 2018
I bought a Robo 3d R1+ a month or two ago, I’ve been having problems with it since day one and I just don’t know how to fix it and even if I did I don’t have too much free time to be tinkering to fix it. I originally bought it for $350ish and had my hot end “break”, I bought a replacement for $60 and now it has new problems and I’ve spent most of my free time trying to fix it and I give up. I have the option to send it to a company to fix it but it would cost at least $150 but most likely $200. So now if I fix it that way it would be around $610 I’ve have spent on this $350 printer. And I just don’t know what to do. If I should repair it and spend the $600 or just bite the bullet and buy the CR-10. I wish I could sell my Robo to someone and use the money to get a new one but I highly doubt anyone would want to buy it in this shape. So please help me with any advice on what I should do.
    Dec '18
    Dec '18
  • 5
  • 1.2k
Not to worry - you’re in the right place!
Could you explain the issues you’re currently having with it? Sounds like there’s a lot - it can definitely be frustrating to get into 3D Printing but let’s see if we can’t sort out the issues and get you back onto printing awesome things :slight_smile:
My printer doesn’t extrude properly, and it seems to never print
when it starts, it doesn’t print for the first 5 secs. Also, It never seems
to work with other slicers besides Mattercontrol (this could just be my fault). Also when you turn it on it makes a weird buzzing sound which it didn’t do before.
Can you show pictures of it not extruding properly?
Not extruding for the first few seconds is normal; the plastic leaks out as it’s heated, so the extruder needs to “catch up” in a sense - this is what a skirt is for, it helps prime the nozzle before the actual print begins.
Depending on the buzzing sound, this could be a misaligned fan which happens quite frequently with cheap ones. Sometimes simply lightly stopping it and allowing it to spin up again can help.
