Hi, I’m new to 3D printing and am a volunteer in an amputee charity in Bolivia. We currently have had an Evolution 2nd Gen 3Dstuffmaker bought for our clinic with the aim to be able to make prosthetic hands for low income amputees in Bolivia. However…this printer is not really functioning as well as we’d like. If we try to print more than one part of a finger at a time it is really poor quality, the fan is inefficient, it will only use one type of material and fails regularly. We’re not sure if the altitude is partly responsible (we are 3600m above sea level). So I have a few questions if anyone can help:-
1) Would altitude affect print quality? Is there any recommendations as a way round this?
2) Would there be a better printer we could look into purchasing for this use at this altitude? We have a budget of between $500-$1000 to purchase a second one.
We make use of Wanhao printers and they have been quite reliable. We have used the Wanhao 4s and the 4x.
If you are interested we have product that could further help you with your printing but I wont write about it here for the risk of being called a spammer
If you are interested get in touch with me at keith@thought3d.com. We would be more than happy to support this cause!!
Hi Amy, I dont think altitude would affect quality (in basic terms, 3d printing is melting plastic and depositing it in the cartesian plane) but im happy to be corrected, with your budget I would look at some of the flashforge and makerbot clones or you could look at the prusa i3s
I can speak about the Wanhao i3 as I use it nearly every day for more than a year. They are very reliable machines if configured properly, you need to install mods also (parts you print to improve print quality / reliability, you will find a lot on thingiverse) and know about slicers. Depending on their size and geometry, each model you print will require slightly different settings, so being knowledgeable about slicers is mandatory. I don’t think altitude will have any impact.
Thanks for your reply, great that’s really useful to know as we will be using it a lot. Once it is set up will it require a knowledgeable user or could it be operated by most people once its been set up by a knowledgeable user?
Depends on the type of pieces. If you’re doing more or less the same kind of pieces (same geometry / size, infill etc) then an initial setup will be enough.
