Aug 2016
Thanks for your help. Yes it prints in PLA only and we wanted to use more flexible material for a more realistic finish. It is really dry here in general but if a lot of people are in the office I guess it could get humid. Always feels cold though.
I will look into the Prusa i3 especially if it has easy set up. Thanks.
I would not suggest printing in PLA if you want your parts to not break when used on a daily basis. If you want a more flexible material that is also really tough, I would suggest printing in Taulman Alloy 910 Nylon. It is much more rigid than normal nylon, but flexible enough to not break when bent like PLA. It prints at 245 degrees C, so it should work with most hotends, but double check yours to be sure. Here is a video with strength tests of the material so you can get a better idea of how it behaves: LINK. I feel like this material would much better suit your purposes.
Thanks for the info and the link, that looks like it would be better. The PLA is not really working for us but the problem is the Evolution 3D stuffmaker says it only prints PLA so would it support this Nylon material? (Your talking to a newbie so forgive my poor knowledge). Does this material come in other colours or is it paintable (to look like a hand)? I will ask the manufacturer about this material too. Thanks.
As long as your printer’s hot end can reach 245 degrees C, it should really be able to print nylon. But if it says that it can only print PLA, they may be using a super weak heater in your printer’s hot end that can only manage PLA temperatures, which are relatively low.
As far as I can tell, it only comes in “natural” color (un-dyed). I’ve never tried to paint this material, as my hub specializes in mechanical replacement parts, so I have no idea how easy/hard it is to paint it. I’m sure it can’t be that hard, honestly.
I checked with the manufacturer, our printer will not print hot enough for this material. I assume the other printers suggested in this thread will though so that might be the answer. Thanks.
1. Altitude should not affect print quality. However high humidity will affect your plastic. In that case, you would need to store the plastic in an airtight container filled with silicone crystals or (my current favourite) kitty litter crystals. Mounting a simple hygrometer will allow you to see what the humidity in the container is. You can buy a hygrometer from good pet stores who stock terrarium supplies, along with the kitty litter :).
2 & 4. I can heartily recommend the Wanhao I3 as an excellent printer at extremely low cost. It comes standard with all the upgrades you’d have to pay for and fit yourself on most other Prusa I3-based printers.
This is a fantastic project - do you currently have any of your designs for prosthetics shared anywhere?
Thanks.
