Hello i hope somebody will reply to this , i just wan to ask if what is better Cura or Slic3r?
Xeno
as long as you don’t use the latest Cura version (new interface and massively Beta),
I think both have pro’s and con’s, and most will advise to use the one they are comfortable to work with,
best would be to learn to work with both
I work with Cura, and gives me the easiest way to get my object printed, and the settings are very clear, but sometimes support is a little finicky to get right, and rotating the object just a fraction sometimes solves this.
what is the difference between the new cura sir Xeno? And What version of Cura software will you prefer?
Thank You
Xeno
I use Cura 15.04, and has still the older interface:
https://c2.staticflickr.com/4/3809/19291096586_2071c05468_b.jpg
and this is the later Cura:
http://static.pokazywarka.pl/bigImages/5908971/15593899.jpg
There is nothing wrong with the new interface, but they totally rebuild the Cura engine, and now there a lot of options missing or not working properly.
Hi Xeno Sorry For the late reply
I try using cura but i dont get the better layer finish , And also i have problem in retraction
Can you suggest some particular settings that can help me. I will really appreciated it
Thank You
